DesmoDue Parts For Sale & Wanted
This section is for all your DesmoDue race parts, accessories and the like.
Old 20-Nov-2011, 15:27   #1
bally71's Avatar
Mood: Inquisitive cat
Class A bike build help engine wanted
Hello
Been racing an 800 in minitwins the past couple of years (met a few of you DD guys along the way) .. and decided to give it a go.
I've got a '99 750 ie that i'd been using as a track bike and want to convert it into a DD bike.
has anyone got an engine to sell?
or does anyone know if I could just swap the barrels/heads
Any advice would be much apreciated
Old 20-Nov-2011, 16:16   #2
Chaz Chaz is offline
Bikes: 916 Strada
Chaz's Avatar
Mood: www.od2racing.co.uk
Originally Posted by bally71
Hello
You can just change the barrels & pistons the crank is the same you would need to check the rods I'm not sure about those pretty sure the heads are ok.
I have a pair of barrels & pistons if your interested.
Old 21-Nov-2011, 09:43   #3
bally71's Avatar
cheers PM me with the details of what you want for them
anyone know any different ..
Is the 620 5 or 6 gears .. the box on the 750 is 5
I'm guessing it would be easier to keep on the boil with the 6 speed??
Old 21-Nov-2011, 10:57   #4
dunlop0_1's Avatar
Personel preferance.
I prefered the 5 speed as 6th gear never really got used. 6 speed are harder to come by.
Old 21-Nov-2011, 22:37   #5
phil_h phil_h is offline
phil_h's Avatar
Hello
The 620 heads - cams especially, like the 800, are better than the 750.
I have a 620 engine that I'm never going to use now if you are interested.
5speed, good condition, but I've never run it.
I'd like 500 for it, but am open to offers.
phil
Old 22-Nov-2011, 23:21   #6
The rules state you need to run standard 620 heads and Cams, the heads are Stamped with the coding 2S (or S2).
So it would be possible to fit heads and Barrels from a 620 to the 750SSie.
I ran my 620 on a 1.5M ECU for a year and Andy Challis did so last year winning the odd race along the way. Although the Rev limiter on them does come in a bit early compared to a 620s ECU
Old 26-Nov-2011, 23:18   #7
bally71's Avatar
Many Thanks guys
Skidlids .. I take it the 1.5M ECU is off the 750 and the 620 is another variant (escuse my ignorance) .. and I take it the looms are the same??
Old 27-Nov-2011, 11:32   #8
Many Thanks guys
The 750SS ie uses a 1.5M ECU, the 620 uses a 5.9 ECU
The 1.5m has a single multi pin connector where as the 5.9M ECU uses two connectors.
As standard the 620 ECU is coded to the Clocks with the Clocks in turn coded to the transponder in the key
As such the looms are very different, even the 750/900SSie had different looms, the earlier one had the fuse box on the fairing bracket the later ones had it next to the battery under the tank, which I have found a lot better for using as a race harness.
This throws another difference into the Mix. The earlier bikes use a A0 version of the 1.5M ECU where as the later bikes/harness uses the A8 version. Main differnce between the A0 and A8 versions of the 1.5M ECU is the way they are interlocked, so can't be swapped from early to late loom and vice versa.
Speaking of 750SSie's and as its sunny out I think I'll take mine for run over to H-Cafe and see who else is out on their bikes today
Old 27-Nov-2011, 17:07   #9
Should also mention the Injectors are different, both use 45mm throttle bodies but the 750 uses early type green injectors that flow 270cc/min where as the 620 uses the later Pico Brown Band injectors that flow 330cc/min.
Both use the same Throttle Position Switch and 3-Bar fuel pressure regulator.
Fitting a PC3 USB to either will allow you to fuel Map each cylinder independantly
Old 27-Nov-2011, 17:43   #10
Brewmaster Brewmaster is offline
Newbie
Bikes: M900ie(2000), SS750ie(2000)
Brewmaster's Avatar
Keep the info coming Skidlids. I have a 750ie setup for racing and am considering converting it into a 620 class A setup. Any suggestions would be SUPER helpful.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 15:55.
