Technical - Help or Info - NON Motorcycle
PC's, Internet etc. Cars, or how to fix that leaky radiator - in here please!
Old 22-Nov-2011, 18:13   #1
deep diver deep diver is offline
Bikes: 900ssie
deep diver's Avatar
Mood: Happy
Repair of Paul Smart Clocks
Good Day
Could any one help? the Speedo on the Paul Smart has stopped working, so the thing is would any one know were I could have them repaired or know of a set at the right price,
Thanking you for you help on the matter.
Fred
Old 22-Nov-2011, 23:07   #2
You sure its the speedo itself and not the speed sensor fitted to the rear caliper mount.
Old 23-Nov-2011, 08:32   #3
Bikes: 900ssie
deep diver's Avatar
Mood: Happy
Hi
Thanks for your reply
I do think that it is the speedo, but will clean up the area around the sensor.
Fred
Old 23-Nov-2011, 14:06   #4
PDL PDL is offline
Bikes: 803 rs race bike
PDL's Avatar
As skids says deffo check the sensor and check all your fuses too. Plus wiring, if you get a short on the same circuit it will stop the clocks working. I think the rear light is on the same circuit
Old 23-Nov-2011, 19:02   #5
I replaced the Speed sensor on my 1000SS several weeks ago as the Speedo wasn't working. Did some diagnostic tests and the readings from the working (good) sensor are different from those of the faulty sensor. It's more than just a wiring fault its the sensor itself
Old 23-Nov-2011, 20:09   #6
PDL PDL is offline
PDL's Avatar
Had the speedo fail on my S4r, changed the sensor and they still didn't work. It turned out I had plugged the cables back in wrongly on the rear light. If there a short on the same circuit the clocks won't work. Worth a try before dishing out 100 plus on a new sensor. The clocks, brake light and horn are also on the same fuse from memory
Old 23-Nov-2011, 22:25   #7
The link I put up for Franco a few days ago was £7.99
Old 23-Nov-2011, 23:34   #8
PDL PDL is offline
PDL's Avatar
Really, Ducati Manc quoted just over 100 when I asked, unless they got the wrong part. It was over the phone. I got one from the states for 30 quid which still is over the top considering your price. I thought 100 was a bit over the top for a magnet and some wires
Old 24-Nov-2011, 22:58   #9
Bikes: 900ssie
deep diver's Avatar
Mood: Happy
Hi
Have cleaned the area and the sencor, lights working all o.k, but it does look as if some one has been playing with the clocks, so this could be the fault.
It looks as if I may have to get some new clocks then.
Old 25-Nov-2011, 21:33   #10
Thats not going to be cheap as NEW clocks cost a rather large packet of folding stuff. I would certainly be eliminating everything else first
As the clocks are coded to the Keys and in turn the ECU is coded to the clocks its not easy just to borrow a set to try as you need to borrow the complete package
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 06:31.
