Old 24-Nov-2011, 09:40   #1
Spjallen Spjallen is offline
Fuel Injectors
Help me if you can....as The Beatles once sung.
Just trying some simple electrics job of fitting a PC to my bike, this isn’t difficult is it? For me, yes its it! Is there a knack or something to removing the electric connectors? Squeeze this way or pull that way?!!
Old 24-Nov-2011, 10:07   #2
paynep's Avatar
Mood: Wet wet wet
You've got to remove the " square C-shaped" wire clip on the connector, or at least open it up enough to get the connector off the injector.
A lot easier to say than do though and make sure that when it pings off via your eyeball it doesnt then get lost!
A small flat screwdriver or needle-nosed pliers work for me, but I've had a lot of practice over the years....
Good luck
Old 24-Nov-2011, 10:25   #3
Chaz Chaz is offline
Bikes: 916 Strada
Chaz's Avatar
Mood: www.od2racing.co.uk
careful you don't break the plastic part of the injector they are not very strong.
A good wiggle dose it for me
Old 24-Nov-2011, 11:15   #4
You only need to push the wire part IN to the plastic body then pull the plug free - no removal needed.
Old 24-Nov-2011, 12:01   #5
Thank you.
Old 24-Nov-2011, 17:55   #6
paynep's Avatar
Mood: Wet wet wet
Surely that's for removing the PC connector, not the OE one?
Mind you I am running standard 620 injectors............
Old 24-Nov-2011, 19:09   #7
chrisw chrisw is offline
Bikes: 999 Mono/1198S
chrisw's Avatar
As Antonye says
Principle is the same as in this video
http://www.youtube.com/watch?v=NVd24ogFYEs
Old 26-Nov-2011, 18:04   #8
Well thanks guys it really was simple, it was just a matter of being brave and getting on with it! Now onto the wire tap and then dyno runs, come on 65bhp!! ( well you can wish! )
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 12:20.
