Old 28-Nov-2011, 10:21   #1
Spjallen Spjallen is offline
Red face Looms
Oh no, time to play with white mans magic, electrickey! Just taking things off that aren't needed such as the left hand handle bar switches, headlights, indicators ect. Now I've got a lot of wiring that isn't really required and would like to get rid of it, the bike will not be returning to the road either so no worries there.
The question is, can I just snip away the excess wiring or will this lead to problems? I can't really afford or justify getting a race loom made option either.
Old 28-Nov-2011, 10:40   #2
bally71's Avatar
Mood: Inquisitive cat
Did the same with my 800 last year .. And electrics scare me too
My advice .. be very careful
Be very patient with it .. disconect it and constantly check everything you want to work still works before cutting anything.
DO NOT CHOP BUNDLES OF WIRES .. YOU WILL STUFF UP
From memory.. all the obvious stuff lights and indicators where pretty straight forward, all the stuff in the tail was redundant .. but be extra careful with the cockpit electrics
And I seem to remember having to make a permanant connection between the wires for the sidestand cut out switch
Old 28-Nov-2011, 14:11   #3
Good advice
Play safe and don't chop anything that can be traced back to the ECU, and be very careful with wires going to the Clocks, a few are safe to chop, such as indicators and High Beam indication
My bike has 3 fuses feeding the circuits where I have done away with the main fusebox. So I now have a Main Fuse, a Injection Fuse and a ECU fuse.
The Charging fuse also remains unaltered
Old 22-Jan-2012, 21:12   #4
Well it's all done now. Chopped just a few. Main beam, indicators and such. Looks so much neater now. Case closed!!
Old 22-Jan-2012, 21:37   #5
Should see what I chopped out of Dallas's and then followed that up by chopping quite a few out of Senna3, As well as getting rid of all the lighting, Indicators, brake and horn wires, we Dumped the ignition switch wiring and the Ignition Relay, Kept the Injection Relay and fitted a Rocker Switch for ON/OFF
Old 22-Jan-2012, 22:42   #6
Getting rid of the key / ignition would be brilliant.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 00:07.
