Old 19-Dec-2011, 10:34   #1
Spjallen Spjallen is offline
Bobbins to you
Guys,
What do you all use on your paddock stands, cups or bobbins? If you use bobbins how did you attach them?
Old 19-Dec-2011, 11:09   #2
Bobbins
Alloy SS arm, I tap and drill the billet bit that locates the adjusters
http://www.ducatisportingclub.com/sh...ad.php?t=85020
On the steel arms I make up threaded inserts from alloy bar that slide up inside the swingarm box section and bolt them from the wheel side of the arm with M8 Domed head allen bolts and from the outside of the arm with M8 Bobbins
Old 19-Dec-2011, 11:48   #3
I must admit that I used the standard (read: cheap!) cups on mine, but I did pack the arms with spacers (thick penny washers) to fix the position they were in, making it easier to get it on and off.
Old 19-Dec-2011, 11:50   #4
Cranker V2's Avatar
Mood: Green with envy
I have done the Same as Skids on my aluminium swingarm. Easy to do and effective. The only advice I would give is to mount a large O/D bobbin that will take the force of a low side or such.
Old 19-Dec-2011, 16:56   #5
NBs996 NBs996 is offline
NBs996's Avatar
Mood: I love my 996 xxx
Bobbins. So much easier than cups.
I just drilled a plain hole and secured inside the swingarm with a washer and nyloc.
Just make sure the fixing doesn't restrict the full movement of the chain adjuster blocks!
Old 19-Dec-2011, 18:37   #6
848spence 848spence is offline
Bikes: Ducati 848 and 583 dd race bike
848spence's Avatar
The previous owner of my bike drilled hole and fitted bobbins in mine but they have used m14 bolts!! They are huge and getting a spanner inside swing arm is a pain in backside, so had to use screwdriver to lock it off to remove them. I'd say m8 m10 bobbins more than substantial. edit edit he he he
Old 19-Dec-2011, 19:21   #7
Originally Posted by 848spence
The previous owner of my bike drilled hole and fitted bobbins in mine but they have used m14 bolts!! They are huge and getting a 19mm spanner inside swing arm is a pain in backside. I'd say m8 m10 bobbins more than substantial.
That was lucky then as M14 bolts usually require a 22mm spanner for the Nut, would have been an even bigger pain
Old 19-Dec-2011, 19:59   #8
I bored a Ø20 hole through both box sections, on the ally and the steel one.
Then welded in a length of bar which was pre drilled and tapped M8x1.25, 50% through.
This then accepts the general ebay bobbins.
Old 02-Jan-2012, 18:25   #9
Thanks guys. As Ive never done this before if I want to tap a M8 size thread what size plain hole do I drill first? Can be as simple as an 8mm?
Old 02-Jan-2012, 19:57   #10
No, for std thread metric fasteners its bolt size minus pitch. so your plain hole will be 6.8mm as a 6.75mm drill bit is not readily available. Or if you only have imperial sizes use a 17/64" drill bit.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 09:37.
