Old 31-Dec-2011, 18:55   #1
steeevvvooo steeevvvooo is offline
steeevvvooo's Avatar
Levers/Braking setup
I've been donated some Pazzo levers from a 696 monster (slightly scuffed, but perfect for the DD bike)
Being a bit of a technical numpty with things like this, any suggestions how to make them fit? I've done like-for-like lever swaps on my S2R, but what do I need to make these fit? A 696 master cylinder? Any others that might fit?
It's Bradder's old bike so has fireblade master cylinder on at the moment I believe and they don't look like they will fit straight on? Single disk and standard caliper if that help by the way...
Old 01-Jan-2012, 01:42   #2
Fireblade would have had Nissin master cylinder as standard and you've got a Brembo, so the levers are totally different! Sounds like you'll need to swap the master cylinder back to a Brembo if you want to use the lever.
Old 01-Jan-2012, 12:05   #3
Thanks for the reply, but a cursory browse on ebay tells me that's going to be expensive/beyond my simple mechanical brain.
Might be best selling the pazzos and just sticking with standard levers
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 10:31.
