Old 02-Jan-2012, 18:42   #1
007 007 is offline
Bikes: 996 Bip
007's Avatar
Mood: CITIUS EST MELIUS!
Question Clutch lever - plunger pin problems
Hello All,
Wonder if you can help, please?
I'm having a spot of bother fitting some aftermarket levers. Brake lever was straight forward, however the clutch lever has proved rather difficult.
I've slackened the small grub screw, but still I find it very difficult to remove the clutch plunger pin from the old lever. Furthermore, there is small flat head screw on the opposite side which as already seen 'some attention' by the previous owner.
Is the plunger pin assembly available as a spare part? Does anyone have one please?
Your help/advice would be greatly appreciated.
Thanks & best regards,
James
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 08:45.
