Old 29-Jun-2004, 12:21   #1
cmoss cmoss is offline
Slipper Clutch
Have Fitted a Yoyodyne slipper to 996 BP, purchased original Ducati sintered plates. But get bad noise when a standing start, have tried putting original(no sintered) clutch plate next to spacer closest to pressure plate thinking its this, but no luck.
When riding all ok.
Am I better off using non sintered plates?, normal road riding.
Any suggestions?
Old 29-Jun-2004, 12:58   #2
Thanks, but don't understand why. At launch it should act as normal clutch only on down shift should it open up.
Old 29-Jun-2004, 13:01   #3
dickieducati's Avatar
i've got an stm one and dont believe it sounds any different to a standard one.
Old 29-Jun-2004, 13:30   #4
Could some one post their clutch plate set-up. Including type of plates and spacers used.
I've tried using dish plates and tried without, just spacer plates, still same.
Old 29-Jun-2004, 13:31   #5
Felix Felix is offline
Sounds like your plate stack height needs adjustment. It should sound just like the standard clutch when setting off.
Old 29-Jun-2004, 13:37   #6
everton
I've got the single progressive spring STM clutch and I think it's quieter.
In fact several other DSC members have remarked on how quiet it is.
Old 29-Jun-2004, 13:38   #7
I think (if I remember rightly from the conversation with the very more technically mined chap...) that it's the plates aligning themselves as they catch and hitting the basket that causes the screeching noise.
Maybe it just needs some WD40 in there?
Old 29-Jun-2004, 14:17   #8
mike916 mike916 is offline
Mood: Neutral - but only maybe. 1994 Duc 916S1, 2006 Duc Sportclassic 1000 Sport
Yeah and then some three bond after to stop the slipping
Old 29-Jun-2004, 14:49   #9
DJ Tera DJ Tera is offline
Don't forgot to put some on the brake discs too - more than doubles their life
Old 29-Jun-2004, 22:25   #10
aws aws is offline
Mood: Super (moto!)
Check the plates.
There is a "dot" on them.
This should always face outwards.
This is most likely the problem.
Also check the correct the height of the stack with the manual.
If you're not correct, the clutch will slip, it's partly your use of the clutch / your method.
Get hold of a verner caliper, and make sure the depth is correct.
This is imperative.
If it's slipping a lot on departure, what can happen is that the clutch will eventuall collapse inwardly as you're placing too much pressure on the pressure plate, which, in time, will fracture - the voice of experience speaking here!
Then you'd best be with the AA!
AWS
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 18:14.
