Old 20-Jan-2012, 18:58   #1
flatline flatline is offline
Bikes: Vtr1000 & 750ss DuCafe Racer. Leeds area
flatline's Avatar
Mood: Upbeat
Fitting aftermarket speedo to 750ss
Would someone tell me what is necessary for this to work on my bike?
http://www.ebay.co.uk/itm/270563314191?ssPageName=STRK:MEWAX:IT&_trksid=p398 4.m1423.l2649#ht_724wt_698
Regards
Old 20-Jan-2012, 23:14   #2
Interesting choice, think you need more details.
Looks like mechanical drive, IF the cables shown are simply for the backlighting inside the drive. If so, then maybe, its just getting the mechanical ratio correct and a cable made to suit.
Old 21-Jan-2012, 00:25   #3
flatline's Avatar
Mood: Upbeat
I'll find out and then..........I'll be back
Old 23-Jan-2012, 17:58   #4
flatline's Avatar
Mood: Upbeat
Its mechanical, says the ratio is 2 - 1 on the ad, whatever that means
Old 23-Jan-2012, 22:44   #5
Different bikes use different ratios to calculate the speed.
You need to make sure that the speedo ratio matches your bike otherwise it won't read the correct speed!
You'll need to do some investigation to find out what Ducati use (chances are they're all the same!) and buy the speedo with the correct ratio.
Old 24-Jan-2012, 13:47   #6
flatline's Avatar
Mood: Upbeat
Cheers for that info buddy
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 12:22.
