Old 31-Jan-2012, 15:36
desmo_pt desmo_pt is offline
1098 Dash connector pins
Hi,
Anyone knows where to find 1098 dash connector pins?
Regards
Pedro
Old 31-Jan-2012, 19:15
chrisw's Avatar
chrisw chrisw is offline
Bikes: 999 Mono/1198S
If it's the same style as the 749/999 then RS Components sell them
http://uk.rs-online.com/web/p/produc...3D4E4F4 E4526
I think I have one cut off an old 999 loom if that is any good
Old 02-Feb-2012, 11:36
Hi Chris do you have a complete plug?
How much do you want for it?
Old 02-Feb-2012, 17:53
chrisw's Avatar
I've got the loom side connector, if that is what you want. It was cut from a damaged loom, so has sufficient wire on it to connect up. I don't want anything for it as it's been in my box of bits for years. Any use to you?
Old 03-Feb-2012, 12:26
Hi Chris,
That would be great! I think i can use the pins form the old plug in the new.
I will send you a pm with my address.
Thank you
Pedro
Old 03-Feb-2012, 17:51
chrisw's Avatar
Just had a look at the connector. I have worked out how the pins are removed. On one side of the connector is a single oblong that is white, on the other, two smaller oblongs that are white. Just push in the single oblong with a screwdriver. Pull the wire and it comes out. Simples.
Do you want them taking out?
Old 03-Feb-2012, 17:59
If you don't mind.
Thank you once more
Pedro
Old 03-Feb-2012, 20:16
Certainly is
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 11:20.
