Old 31-Jan-2012, 22:47   #1
fastphil fastphil is offline
fastphil's Avatar
Mood: building up
999R cams
Has any 1 got the Lift and degree measurements for 999R cams ?
Old 01-Feb-2012, 10:01   #2
fastphil's Avatar
Mood: building up
Or know where I can download a 999R 04 workshop manual as I have got a 999RS 04 workshop manual which gives setting for CA525 cams or CA478 cams which are checked at 5mm lift
Old 01-Feb-2012, 12:26   #3
'03/'04 are
Intake opens 16 deg BTDC, closes 60 deg ABDC
Exh opens 60 deg BBDC, closes 18 deg ATDC
Lift with zero clearance Int 11.71mm Exh 10.13mm
'05/'06 are different
Intake opens 21 deg BTDC, closes 53 deg ABDC
Exh opens 60 deg BBDC, closes 20 deg ATDC
Lift with zero clearance Int 13mm Exh 11.5mm
Old 01-Feb-2012, 12:38   #4
fastphil's Avatar
Mood: building up
cams are marked 5R ? just checked they are 05 999R cams
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 04:50.
