DesmoDue Parts For Sale & Wanted
This section is for all your DesmoDue race parts, accessories and the like.
Old 12-Feb-2012, 19:11   #1
Cranker V2's Avatar
Mood: Green with envy
Race loom.....damn electronic stuff
Wanted, so i can at leat attempt to start the shed mk2, a race loom for a 620ie motor. Or even someone who knows where one can be made for me. Being a clanky sometimes does have its drawbacks...................
This could be the staw that breakes the camels back and sees me not enter BRands round.
Mike, stuck in a world of splicing, soldering and throwing paddy fits.
Old 12-Feb-2012, 19:53   #2
Reminds me I have to convert Matt Larretts Harness tomorrow see if we can het his 620 Engine running in his old Class B bike, that'll be the 3rd one in recent months
Old 12-Feb-2012, 20:02   #3
Cranker V2's Avatar
fancy doing another? plenty of beers tokens in exchange?
Old 12-Feb-2012, 20:11   #4
Be finding the time Mike, especially if complicated
Madmostin also wants me to pop up to West Brom and do the Harness on his Monster 620
For tomorrow, Matt had a 620 Multistrada loom but thats not suitable for the ECU he is using, neither was the Air temp sensor, so I'm going to have to adapt a loom off of S4R I had lying around
Q1/ Do you have a Standard Monster of Supersport 620 Loom as a starting point
Q2/ are using 620 Coded ECU
Q3/ are using 620 Coded Clocks
Q3/ are you going to be needing the Key Transponder (normally answered by the questions above)
Q4/What Coils are you using
Old 12-Feb-2012, 20:43   #5
Cranker V2's Avatar
Q1/ Do you have a Standard Monster of Supersport 620 Loom as a starting point - Yes standard 620ie monster loom
Q2/ are using 620 Coded ECU - Yes, sent away to be virginised
Q3/ are using 620 Coded Clocks - No
Q3/ are you going to be needing the Key Transponder (normally answered by the questions above) - N immobiliser finction disabled
Q4/What Coils are you using - Standard monster 620ie ones - unless there is a better alternative???????
I know you are busy Kev. if you can siggest a company to it I would be happy.
Mike.
Old 12-Feb-2012, 21:29   #6
Mike
Virginised and IMMO OFF are two different things
A virginised ECU still needs the clocks where as one with the IMMO Function removed or disabled does not
Can you clarrify which as both are mentioned in your post above
Old 12-Feb-2012, 21:39   #7
Cranker V2's Avatar
immo off
Old 12-Feb-2012, 22:36   #8
Bit like Senna3's conversion then, although we kept 5 of the clock wires for the SSie Tacho, temp gauge and oil light.
Is it from a 2002 model or later as the Start interlocks are different
Old 12-Feb-2012, 22:59   #9
Cranker V2's Avatar
its a 2002 reg bike, not sure on build year.
Old 12-Feb-2012, 23:44   #10
It would be 2002 build as thats the first year of the 620. So your not talking fitting a 620 engine into a 600ss Chassis but using a complete 620 Monster, which makes life a lot easier
I'll see how I get on tomorrow Mike but I could be up for it
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 03:20.
