Old 19-Feb-2012, 15:29   #1
ells ells is offline
ells's Avatar
Lack of petrol flowing
Out at Oulton yesterday and a previous afliction reared its head. After a few laps (5/6) the old girl ran out of puff at turn 2. As they had limited marshalls I tried to limp home and after knickerbrok she suddenly had a second wind!
Second session and the same happened again
Now I had an issue at Snetterton last year thta felt like a fuel issue, I had the carbs stripped and rebuilt and set up for the new pipes in time for Cadwell and it were fine at the end of last year. Now the Mrs did drain my tank to the bottom for the petrol!
Got the bike out today, started to drain the tank and what started as a good flow turned into a trickle. Then after unscrewing the petrol cap (replacement race item) the flow was restored!
I suspect either
1. there is rubbish in the float bowl again
or
2. The flow is not enough
Its a monster tank with the vacuum pump (which I thought we bypassed but I may be wrong). How does the air get back in the tank to replace the fuel going out of the tank so we dont get a vacuum? There seems to be no hole in the race fuel cap although there looks like a mini ball bearing (0.5 to 1mmm in size). The SS tanks used to have a pipe on the top with a valve? What does the monster get?
Am I looking at the right thing or am I going to have to pull the carbs kff to look at the float bowl.
Tried blowing through the fuel cap to see how air could get in and it did not seem to work.
Very puzzled bloke
Old 19-Feb-2012, 16:52   #2
I suspect either
or
Very puzzled bloke
Hi Mark,
I do believe it may be your tank not being able to breath, remove the filler dap and remove the ball bearing, replace and try again, this is what happened when I put a Chinese one on my 748.
Old 19-Feb-2012, 17:19   #3
ells's Avatar
Having chatted to local mechanic he too suspects the lack of the tank to breathe. Cant see any way to remove the ball bearings but will have a good look.
Cut open and inspected the fuel filter. Learnt its ok to blow through the fuel filter but sucking is a silly thing to do.
Little bit of rubbish on the tank side of the filter (need new filter now I have cut it open.)
Tried blowing past the ball bearing from both sides but to no avail. Definatelt lack of air. Get a good old hiss when I open the cap. I suppose drilling out the ball bearing is not acceptable on a race bike.
Mark
Old 19-Feb-2012, 17:26   #4
Mark
Drilled mine out, so do not see why you cant.
Old 19-Feb-2012, 17:47   #5
numbskull numbskull is offline
Bikes: 848 Evo ‘Pikes Peak’, 748S, 200 Single
I drilled a hole in the filler cap on my race bike.
Never failed scrutineering or let out too much petrol during a race!
Old 19-Feb-2012, 17:52   #6
ells's Avatar
Woo Hoo,
out with the drill then. Cheers Chris and Neal
Mark
Old 19-Feb-2012, 19:03   #7
Although two scrutineers now know about it
Old 19-Feb-2012, 19:37   #8
Spoilsport
Old 19-Feb-2012, 19:43   #9
Maybe buying a new filler cap unit may be needed to keep the scrutes happy
Old 19-Feb-2012, 20:20   #10
And one of them is using it this year I believe?
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 09:36.
