Old 04-Mar-2012, 21:57   #1
jangol jangol is offline
Bikes: 1098s, 749
749 Nightmare to Start
Hi,
Not long had my new 749.. its a 2003 BP...
From cold its a nightmare to start... is this the norm or does anyone have any pointers...
Its not been ridden for a while (due to the weather etc..) its plug into an battery optimiser....
which I'm hopping should be keeping the battery charged...
Old 04-Mar-2012, 22:11   #2
Maybe stale fuel
Old 04-Mar-2012, 22:43   #3
Cobbett Cobbett is offline
Bikes: 750ss, 998s
Cobbett's Avatar
Do you know if the fuel filter has been changed? Lots of places quietly skip it as it's a pain to do. But in my experience an old, clogged fuel filter is often the reason for poor starting which wrongly gets put down to battery, plugs etc.
Old 05-Mar-2012, 00:33   #4
hugh jaynus hugh jaynus is offline
hugh jaynus's Avatar
Mine did this even with a fully charged battery , turned out to be a poorly attached earth to the battery. Worth giving it a tug and seeing if it comes off
Old 05-Mar-2012, 20:42   #5
Bikes: 1098s, 749
Thanks will change fuel filter as a start!!
Old 24-Mar-2012, 23:18   #6
casey749 casey749 is offline
Newbie
Bikes: Ducati 749
casey749's Avatar
First of all, check (clean and grease) all connectors between battery, relay and starter motor; also clean connector on earth wire bolted to engine and earth wire fitted to ECU.
Next step good battery, gel would be better than acid.
Old 26-Mar-2012, 20:42   #7
Bikes: 1098s, 749
Stuck a set of plugs, cleared out the air filters.. put all back together, started 1st time...
Was over the moon..
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 00:58.
