Old 05-Mar-2012, 22:15   #1
848spence 848spence is offline
Bikes: Ducati 848 and 583 dd race bike
848spence's Avatar
Angry For FOOORRKK sake!!!
With only days to go before the first round, my fork seal has given up!!! its now dripping off the bottom of the stantion. I only did these seals about 3 trackdays ago. So think i will be hunting for some new ones between next rounds. But for now going to change the seal again. Thing is I have forgotten how much oil i should put in each leg. So going to have to empty both. What is it about 375ml?? from memory, have used the search button but cant find the info needed
cheers
But on a positive note, had the bike dyno'd today and she is running sweet as a nut and putting out 52.09bhp
Old 05-Mar-2012, 22:39   #2
Still have the later type for sale, 65mm Caliper mounts and 25mm spindle
http://www.ducatisportingclub.com/sh...ighlight=Forks
Old 05-Mar-2012, 23:15   #3
numbskull numbskull is offline
Bikes: 848 Evo ‘Pikes Peak’, 748S, 200 Single
I have an early pair of forks for the single disc that have been set up for an 11 stone rider.
Old 06-Mar-2012, 14:34   #4
848spence's Avatar
Bradders is a good lad. Sorting me out with a set of forks. But what's a good base setting in regards to oil and air gap??
Old 06-Mar-2012, 16:20   #5
reckon you'll be ok - they were set for Nick whos about 9st wet thru!!
Old 06-Mar-2012, 17:42   #6
kiwicoops kiwicoops is offline
Bikes: M620ie, DD583R #30
kiwicoops's Avatar
In the workshop manual for Showa forks its 440cc and 108mm gap, and for Marzocchi, 390cc and 90mm gap to top of leg. What actually goes in there is one of the so called 'Black Arts'. I've got 100mm gap, why?, thats where Woods set it, seems o,k comresses down to 20mm from bottoming out.
Pete
Old 06-Mar-2012, 17:47   #7
check out Chris P post in the DD info section - very useful data sheets and advice.
Old 06-Mar-2012, 21:37   #8
Which Marzocchis is that Pete, the early 600 ones (up to 1999) or the later ones from the 2000/2001 Monster 600 and carried on into the Monster 620/800s
Old 06-Mar-2012, 22:10   #9
848spence's Avatar
Bikes all back together thanks again bradders
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 09:37.
