Old 09-Mar-2012, 22:20   #1
jangol jangol is offline
Bikes: 1098s, 749
749 Clutch
Hi,
Was in the process of changing my clutch & pressure plate over this afternoon to find out my clutch plates are knackered...
Any ideas of what makes I should be looking @ & where I should be looking
Also I'm after a Clutch Hub Assembly.. had a little accident removing a spring?
Any ideas on where I could get a replacement or where I could get it mended if poss
Old 09-Mar-2012, 22:37   #2
chrisw chrisw is offline
Bikes: 999 Mono/1198S
chrisw's Avatar
If no one comes along with the part for you then Jim Redmond is always worth a call 01708 455530. You will also need to get your hands on a clutch holding tool and a big f**k off breaker bar and torque wrench as that centre nut is 190nm!
Old 09-Mar-2012, 22:44   #3
Bikes: 1098s, 749
Cheers, What's the clutch tool used for... can a clutch change be done without one??
As just looked @ a price for one?
Old 09-Mar-2012, 22:51   #4
Bikes: 1098s, 749
Just answered my own question.. I think?? only used if I changing the clutch hub right??
Won't need it if I just change the plate only right??
Old 09-Mar-2012, 22:55   #5
chrisw's Avatar
Yes just the hub, as in
Old 09-Mar-2012, 22:57   #6
Bikes: 1098s, 749
Cool Thanks...
Hope someone has a bargain on here.. as going to cost a fair whack for a hub & plates...
Old 10-Mar-2012, 00:12   #7
There are cheaper alternatives!
Just google for "ducati clutch tool" and you'll find the version that bolts onto the case and allows you to hold both the centre and the clutch basket to allow easy removal of both.
Old 10-Mar-2012, 18:46   #8
Bikes: 1098s, 749
thanks for the reply..
if anyone has a decent clutch kit for a 749 plse let me know
Regards
JA
Old 11-Mar-2012, 21:53   #9
chrisw's Avatar
Anybody got one of these? Any good?
http://www.ebay.co.uk/itm/1808001857...=p5197.c0.m619
Old 14-Mar-2012, 22:19   #10
Bikes: 1098s, 749
just brought one... looks decent, didn't get 2 use it in the end as i used an air gun to remove my clutch....
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 17:08.
