Old 04-Jul-2004, 20:48   #1
PeteC PeteC is offline
Broken body/side panels
There I was flicking the St thru my favourite corners on the A483 when I felt something flapping by my left knee.
I looked down and thought "Golly gosh, oh my..that shouldn't be doing that"
A quick inspection under the seat confirmed the worst , the little lug where the side panel is bolted to the frame with an 8mm (head) bolt had decided it no longer wanted to ride along with the rest of the bike, maybe I had frightened it,but anyway has anyone else had this happen, and does anyone have a fix , or is time to get the chequebook out?
(My bike is only two months out of warranty too )
Pete
[Edited on 4-7-2004 by PeteC]
Old 04-Jul-2004, 20:57   #2
Can you be a bit more specific about which bit has actually broken? Is it the mounting on the frame or has the bit of plastic just disappeared?
Old 04-Jul-2004, 21:19   #3
Rushjob Rushjob is offline
Rushjob's Avatar
Mood: :-)
I had this part split on my ST2 and the knurled brass insert that the bolt goes into came free from the plastic moulding it sits in.
Two minutes with some superglue & it was ok for the next 10,000 miles or so & as far as I know, it's still ok to this day.
Andy
Old 04-Jul-2004, 21:23   #4
Glyn Glyn is offline
Glyn's Avatar
Mood: st2......we can rebuild
same as above , but i also put a jublee clip omn the offending bit
Old 04-Jul-2004, 21:25   #5
Rushjob's Avatar
Mood: :-)
I thought about that Glyn but decided against the extra weight.......
Andy
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 19:03.
