Old 17-Mar-2012, 20:17   #1
merlins dad merlins dad is offline
Bikes: 999s
merlins dad's Avatar
converting to radial brakes
I would like to upgrade my brakes on my 04 999s, any one done this before and can offer advice on what is needed i.e new discs/calipers etc and what size?
Old 17-Mar-2012, 21:39   #2
khu996 khu996 is offline
khu996's Avatar
Has your 999S already got Ohlins forks? If so, you could just replace the fork bottoms and get 100mm spaced radial calipers to match? You can use the same discs, I think they're all 15mm offset.
Old 18-Mar-2012, 00:38   #3
You can get adapter brackets of www.ebay.it
http://www.ebay.co.uk/itm/3101719442... 4.m1438.l2649
I have a set of the 4-Pad radial calipers as found on a 999 that will be going on ebay tomorrow
Dallas uses just the left side on his DD bike
Old 18-Mar-2012, 13:11   #4
[quote=skidlids
Dallas uses just the left side on his DD bike[/QUOTE]
and its stops pretty f***in well!
Old 18-Mar-2012, 17:07   #5
hugh jaynus hugh jaynus is offline
hugh jaynus's Avatar
are radials that much better than normal brakes?
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 20:58.
