Old 19-Mar-2012, 20:10   #1
jangol jangol is offline
Bikes: 1098s, 749
749 Which Plugs to use>
Guys...
Still getting used to all this self maintenance lark
I've owned 3 748's (a few years back), after 4 years without a bike, I picked up a early 749...
as Per a previous thread, its such a pain to start, so I'm just working through what may be causing it..
What spark plugs would do a good job...
any ideas would be a great help...
Regards
JA
Old 19-Mar-2012, 22:26   #2
The handbook says the standard plug is a Champion RG4 HC,....or you could use an NGK CR9E.
Just be aware when you change plugs,you will need a very thin walled socket to get them out.There aint a lot of room in the head recess.
Old 19-Mar-2012, 22:56   #3
Removal is a bit easier with the Champions than with the NGKS
Old 20-Mar-2012, 13:05   #4
RickyX RickyX is offline
RickyX's Avatar
My 749 was a pig to start when I first got it.
I put a new battery in it and it starts first time now, even when it has been sitting unused for weeks (not even on a trickle charger).
RX
Old 20-Mar-2012, 18:04   #5
Bikes: 1098s, 749
Thanks guys...
Took 1st plug out (the easiest one to get to ) which was a NGK CR9E, it looked a little worse for wear to be honest, ordered a pair of them! turning up 2moz,
I should have removed the seat & tank to get to the other one by then (I'm guessing that's what I need to do, to remove it
Ordered a new fuel filter to.... as I'll have the tank off, to get to the 2nd plug...
Battery is always on a charger, but could be @ fault also.. will give it a test 2moz....
Old 24-Mar-2012, 23:12   #6
casey749 casey749 is offline
Newbie
Bikes: Ducati 749
casey749's Avatar
I have done service last month. I fitted new plugs (NGK iridium) and bike was starting poorly. I decided to fit back genuine Champion RG4HC and engine started at firs time. I think iridium is ok on hot weather.
