Old 15-Jul-2004, 13:01   #1
springer springer is offline
Clutch question
What’s the black rubber insert in the clutch reservoir for. It almost fills the reservoir and leaves little space for fluid. Can I live without it?
Old 15-Jul-2004, 13:10   #2
Dave G Dave G is offline
Dave G's Avatar
I'm no technoguru but I thought it was to minimise the airspace in the reservoir,it wont improve anything getting rid of it,so I'd keep it.
Its the same for the brakes too.
Old 15-Jul-2004, 13:17   #3
keefer keefer is offline
keefer's Avatar
it somtimes gets a bit out of shape as the fluid goes down, take it out and put it back in shape, bleed your brakes while your at it, top up with fuid to the upper marker whip it all back together and the job is job'd
Old 15-Jul-2004, 13:19   #4
ali ali is offline
ali's Avatar
Mood: Damp
I was always under the impression that clutch/brake fluid is susceptible to contamination from humidity and air (both water & air compress a lot more easily than hydraulic fluid) so the rubber minimises the amount of air that the fluid comes into contact with.
As always, I reserve the right to be completely wrong.
Cheers,
Ali
Old 15-Jul-2004, 13:34   #5
Derek Derek is offline
Bikes: ST4s ABS
Derek's Avatar
It is also the seal that keeps the fluid in and the air/moisture out. Leave it where it is if you want your clutch fluid and pistons/seals/cylinders to stay in good nick. It is collapsible and should be pressed flat into the cap when fitting after topping up the reservoir. There are similar ones in the brake reservoirs.
[Edited on 15-7-2004 by Derek]
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 21:53.
