Old 16-Jul-2004, 15:12   #1
ride height
I have set the front height at just under the 4th ring on the top of the forks. Mine only has 4 rings, and I thought they had 5!! I am a bit concerned that the distance between the front wheel and radiator/top fairing may be an issue. But, I think I can take it to the lowest ring right?? Also, I guess I will need to firm up the front, as my forks compress to within 1mm of bottoming out under emergency braking!
Questions:
*is it safe to drop to the lowest ring (measured at the lowest point of the ring)
*how much travel should I have left in the forks to be safe/not damage anything
*how much static sag should there be and should it feel 'sticky' when pulled onto the stand
Thanks,
paul
Old 16-Jul-2004, 16:03   #2
DJ Tera DJ Tera is offline
You should have at least 1-1.5cm unused fork travel
Oh and this place recommends dropping the forks like you have www.section8superbike.com
Old 16-Jul-2004, 17:23   #3
Yep helpful lot Section8superbike could be why I'm wearing their T-shirt at the moment.
I went for stage 3 on the 998 Hybrid
Old 17-Jul-2004, 11:53   #4
Kev - maybe you can cast an eye over it tomorrow for me...weather permitting
Old 17-Jul-2004, 12:20   #5
Ok Paul- weather permitting.
I hope its sunny.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 18:15.
