Old 16-Jul-2004, 21:18   #1
mike916 mike916 is offline
Mood: Neutral - but only maybe. 1994 Duc 916S1, 2006 Duc Sportclassic 1000 Sport
Early 916 recall for rear stub axle check
Anyone remember the recall on 916's last year for the rear stub axle to be xrayed and checked for hairline fractures? Well I had one last year and dutifully presented my 94 Strada to Speedaway in Birmingham to have the check done and all was pronounced OK
Today I have reliably (I think!) been informed that because mine is an early bike which is fitted with a axle which has a parallel bore all the way through it should have been changed as part of this recall for the later stronger type of axle which you can identify by it's stepped bore (which is caused by an increase in metal thickness in critical areas)
I've always wondered why I has a step on the shaft of my paddock stand but it seems obvious now
Can anyone confirm if this is correct or not and if so what's the odds on it still being possible to get this potential and possible lethal defect remedied by Ducati. Can't think why it wasn't done at the time unless they had none in stock but you would have thought they could have at least told me it needed doing!
I will be travelling at much reduced velocity until I have got this one sorted out and I think a call to Ducati UK is on the cards
Old 17-Jul-2004, 10:28   #2
TopiToo TopiToo is offline
Bikes: 748ish . .
Mood: Sampai jumpa lagi
Hello mike916,
For peace of mind I would phone Ducati UK, as with all things you will hear contradictory opinion.
regards
TopiToo
Old 19-Jul-2004, 13:33   #3
If anyone is interested I phoned Ducati uk today and they said that the stub axle does not need changing
This is because it had passed the xray test. Thay also said that nationally there were actually very few that needed to be changed
[Edited on 26-7-2004 by mike916]
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 18:16.
