Old 17-Jul-2004, 16:00   #1
moto748 moto748 is offline
748E fuel lines
Anyone know of anybody doing a kit to convert the 748E to quick-release fittings?
I've been told it could be quite expensive!
Old 17-Jul-2004, 21:04   #2
Mark853 Mark853 is offline
Mood: The medication helps!
Ducati!
Try a breakers?
Old 18-Jul-2004, 10:18   #3
The connectors are available from Ducati. They aren't cheap though, but probably no more than buying a s/hand pump and fuel lines.
Have a word with JHP or such like.
Old 18-Jul-2004, 16:38   #4
Thanks.
I was half-hoping someone would say they'd done it with a few after-market couplings. I know you can get them from M&P and suchlike, but I don't know if they'd be suitable.
I may make some enquiries at my friendly local Ducati dealer.
Old 18-Jul-2004, 16:48   #5
keefer keefer is offline
keefer's Avatar
that is prob the cheapest way to do it, put some in line on the fuel pipes. i have seen the connectors you mentioned and they look very similar. only the factory one's fit into the pump base. but as mentioned above you would need a second hand base as the bore is larger. id put them in the fuel line easiest way to do it
