Old 19-Jul-2004, 21:11   #1
iang iang is offline
iang's Avatar
Would a 999R termi fit a 749R ?
I have the chance of a 999R termi for about £350 but did not know if it would fit the standard pipes on my 749R.
I know the link pipes would not fit but could i use the standard pipes with the cat in until i got the correct link pipe, or would it run fine with the cat left in ?
Also would the bike run ok with the standard ecu and filters or is it not worth the hassle.
Any views appreciated
Old 19-Jul-2004, 21:25   #2
When i first fitted the decatted stuff on my 999r i ran it without changing the cpu first. I was convinced it went smoother.
Then i fitted the cpu. We both know the best way is to get it set up on the proper machine (maffis?) which i did.
Any way you want to check you have the latest cpu, tell them its missing or stalling, to get it changed/checked.
Old 19-Jul-2004, 21:25   #3
Oh im sure the mounts etc are the same 999 / 749.
Old 20-Jul-2004, 08:36   #4
Mood: going for a ride...
If the 999R termi system is from an 03 bike with the cast swingarm it will NOT fit your 749R , the fabricated swingarm is much deeper so the long pipe from the horizontal cylinder is a different shape.
If however the system is from an 04 bike it should fit fine.
The bike will run fine using the standard ECU , you may not get the absolute power gains from the pipe that you would using a specific ECU for an assymetric termi but the 999R ECU will not work on your bike once it has been fitted to a previous bike , a replacement ECU from Ducati is £450
Old 20-Jul-2004, 21:19   #5
Originally posted by yellowisfriedegg
.....a replacement ECU from Ducati is £450
or you can fit a PCIIIusb (haven't we done this one before)
Old 21-Jul-2004, 00:26   #6
iang's Avatar
The guy has decided to sell the full set up from the 999R.
It is an 03 model with link pipe, filters and ecu but he wants between £700 - £750 which i do not want to pay as i can get the correct one for not much more.
Old 21-Jul-2004, 08:50   #7
As I said , it will not fit anyway , an '03 bike will have the cast swingarm , I have already tried a front pipe from a system designed for the standard swing arm and it fouls on the bottom of the fabricated swing arm , also the mounting point by the footrest does not match
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 23:16.
