Old 19-Jul-2004, 22:49   #1
Bungi Bungi is offline
996R front sprocket / renthal?
I want to know if ive got the right front sprocket, before giggleing around and taking off the original,
i first noticed that the sproket on my 996r is retained by a lerge nut as opposed to the regular two bolt through a plate on the other models, os this has made me suspicious as to if i have the wrong one, althoght the spline seems the same???
i cant seem to find a web site that i can check this part number of a rental sprocket i have for a regular 996 to see if its the same.
can anyone help? part no is 344--525-14p
Old 19-Jul-2004, 22:52   #2
Mate, the later type final drive front sprocket is held on with a large nut and lock washer.
The old style used two bolts and a plate.
Old 19-Jul-2004, 22:56   #3
the 344-***-** is for the regular Ducati' using a splined lock plate. I can't remember the part number suffix for the 'stretta motor but it is a different sprocket. It doesn't have the raised boss on the back either.
Drop me a mail with chain size and teeth required and I'll find the part number for you.
Old 19-Jul-2004, 23:50   #4
wil u2u nelly thanks
Old 19-Jul-2004, 23:55   #5
hell the u2u not working, or is it just me??
basically i just want the correct 14 tooth front sprocket for a 525 chain. just fitted a 37 t rear and so going the one up on the rear will hopefully put the hub back in the right place???!!!???
Old 20-Jul-2004, 20:29   #6
have u2ud u nelly
does any one have a good contact for a renthal sprocket supplier??
Old 20-Jul-2004, 21:01   #7
smilo006 smilo006 is offline
smilo006's Avatar
Mood: I like my bike
http://www.bandcexpress.com/road_spr...n_manf=Ducati:)
Old 22-Jul-2004, 21:45   #8
thanks guys now sorted
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 18:15.
