Old 27-Mar-2012, 22:24   #1
Spjallen Spjallen is offline
Red face Swingarm pivot bolt removal
Hello again. Just aquired a nice alloy swing arm, but how do you remove the pivot bolt? Do you need some overpriced use once only (hopefully) ducati special tool??
Old 27-Mar-2012, 22:34   #2
paynep's Avatar
Mood: Wet wet wet
If you mean the pinchbolts they are just 8(?)mm hex socket bolts and then the spindle just drifts out.
Unless you've bought one where the chain has been loose and has knackered the left hand pinchbolt head by peening it over and filling it with alloy swarf so it wont turn in the recess.....
Took me 4 hours to salvage mine with cunning use of drills, drifts and a big hammer!
Old 27-Mar-2012, 22:44   #3
Is that all that holds it on? Those two pinch bolts?! Do you just knock it through with a drift?
Old 27-Mar-2012, 22:49   #4
Unless it has the circlips on the end which will need to be removed from one end first, then drift it out and try not to damage the shims
Old 27-Mar-2012, 23:00   #5
Thank you. More scary stuff happing in my garage tomorow then!
Old 28-Mar-2012, 09:34   #6
hey if I can do it, anyone can!
Oh no, hold on, Snells did mine
Old 28-Mar-2012, 17:19   #7
Lightweight!! Do I need to change my axle axle? Current one seems too long. Too may axles!
Old 28-Mar-2012, 18:06   #8
Are you talking wheel spindle axle, or swing arm pivot spindle axle??
Old 28-Mar-2012, 21:20   #9
paynep's Avatar
Mood: Wet wet wet
If its an axle axle, then he means both.
Or that could be why its twice as long as it should be!
Old 28-Mar-2012, 21:21   #10
Don't know about SS but the St one which went on my monster needed a longer axle, although swing arm pivot was ok
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 12:20.
