General Motorcycles only
Old 23-Jul-2004, 14:19   #1
Loz Loz is offline
Loz's Avatar
Oil Light
Hi gang
My '01 750 Sport has started putting its oil light on at unexpected moments. It's always when the engine is hot and it can occur at any revs (it may be that it comes on after I have hit 6000+ rpm, but I'm not sure).
Switching the ignition off and on turns the light out for a short while, but it soon returns. The temp gauge is reading between 1/3 and 1/2, and there are no wild fluctuations in the readings. There is sufficient oil in the case.
Has a sensor gone? I'm flummoxed (not difficult where mechanisms are concerned). Thanks!
Old 23-Jul-2004, 14:49   #2
748mart 748mart is offline
Oil pressure switches are not reliable. First step is to replace the switch.
Cost about £10.
Martin.
Old 23-Jul-2004, 15:00   #3
Loz Loz is offline
Loz's Avatar
Cheers Martin.
Are they a fit-it-yourself part or a get-someone-who-knows-how-to-use-a-spanner part? I'm a reluctant mechanic at best (maybe "dreadful" is a better description?)
Old 23-Jul-2004, 16:07   #4
Yes you can fit youself, you will need an open ended spanner to suit th switch which is about 24mm.
Be very carefull not to overtighten the switch as they will easily snap.
Old 23-Jul-2004, 16:24   #5
Desmondo Desmondo is offline
Mood: :devil:
Yep, could well be the OPS. Check for small oil leakage around the unit.
Mine cost me £18 only about a month ago and is easily swapped in 5 mins. Just unplug the connector at the top and unscrew the main unit. Screw in th new one, and as mart said, don't over tighten as the do snap. Plug in the connector again and away you go.
Old 23-Jul-2004, 16:41   #6
Loz Loz is offline
Loz's Avatar
Martin & Desmondo
Cheers, mates. Just checked it all out, it's a doddle. I shall firstly try the "take it apart, then put it back together again" approach to see if that fixes it. Hey, you never know!
I you both (plus I owe you some petrol, too, Desmondo)
Old 01-Aug-2004, 00:00   #7
*ahem*
Old 23-Aug-2004, 18:02   #8
Loz Loz is offline
Loz's Avatar
Well, might be speaking too soon, but changing the OPS seems to have cured the "oil light coming on" problem.
Many thanks once again, Martin and Jamie!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 13:04.
