Old 27-Jul-2004, 20:24   #1
moozaad moozaad is offline
Bikes: Ducati ST2
Mood: Fruity
paint
Hi
does anyone know the paint code or eqivalent paint for a (very)dark grey/black 2000 reg ST2?
cheers
Old 28-Jul-2004, 11:19   #2
If you look in the back of the owners manual it should tell you the names of all the colours for that particular model year. If you don't have the owners manual it's available by clicking on this link and downloading it
Once you know the name of the colour, you can go to a paint factor who stocks PPG paints (PPG are the paint manufacturer that Ducati use) and they will have the right colour codes and the colour formula so they'll be able to make it up for you. You can contact PPG the UK on 01753 611500 if you want to find a local stockist.
For the DIY market, they should be able to make up aerosols if you don't have a compressor and spray gun, and you'll most likely find that the finish is what's called base coat and lacquer where you build up 4 or 5 coats of base colour, flat it back to a matt finish with 1500 grade wet & dry, then squirt clear lacquer over it to make it glossy again.
DIY aerosols are OK, but they don't give you a huge amount of chip resistance, so if you're doing anywhere that might suffer from stone chips you might be better off biting the bullett and getting it done professionally. They'll use two-pack paint and two pack lacquer which is epoxy based and much harder. They won't sell you that if you are a DIY'er because it gives off poisonous fumes until it's cured so you need to have some sort of license to prove you've got a suitably equipped spray booth and breathing equipment.
Old 28-Jul-2004, 13:57   #3
Bikes: Ducati ST2
Mood: Fruity
Hi
I can't find the paint codes, I checked my manual and downloaded several ST2 manuals of different years and searched for the paint codes. I must be going blind...
What I really need it those touchup pens that you can get. My scratches/stone hits are only minor but trust ducati to use a white base
I've found metalic grey in the 2003 manual but I think thats most likely to be the newer colour. Mines the very very dark grey, almost black one. It's definitely not in the earlier manuals
Old 28-Jul-2004, 17:31   #4
Bikes: Ducati ST2
Mood: Fruity
Got a reply from ducati UK I'll put it here for reference incase someone else needs in sometime
BASF 291.500 - Black/dark grey for 2000 model ST2s
Old 28-Jul-2004, 17:47   #5
Bikes: Ducati ST2
Mood: Fruity
the next question is; anybody know a supplier?
Old 28-Jul-2004, 18:59   #6
chrisw chrisw is offline
Bikes: 999 Mono/1198S
chrisw's Avatar
Paint
If PPG are the supplier then try this link
I am sure they will put you in touch with a local supplier
http://www.ppg.com/refineurope/phase...ntactUsMsg.asp
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 11:17.
