Old 02-Aug-2004, 21:25   #1
Ian900SLV Ian900SLV is offline
Mood: All SP'ed up at the moment
Front Brake Pads
Hi Guys,
Anyone got any recommends on type and make of pad to use on the cast iron rotors on a Superlight. I am right in thinking that a sintered pad is a no-no on this type of rotor ???????
Ian
Old 02-Aug-2004, 23:59   #2
Mike Davis at Robsom Racing and Nelly at Cornerspeed both seem to be fonts of Knowledge....
I bought some semi-racing Bendix pads from Mike and am very happy with them so far.
I cant remember the recommendation for Iron rotors - I vaguely recall using organic pads on the ones I had years ago but you would need to check it out with a professional (EBC as well maybe???)
Good luck
Old 28-Aug-2004, 08:36   #3
edwyun edwyun is offline
Yes, you should not use sintered pads on the cast iron rotors. Some i know do without much problems, but YMMV.
As for me, I use Performance Friction Carbon Metallic compound 95 - AWESOME stopping power with the cast irons.
[Edited on 28-8-2004 by edwyun]
Old 28-Aug-2004, 11:00   #4
Ian, the Bendix MF compounds have proved fine with iron rotors, despite being sintered. SBK3's eat them. I think also that EBC HH don't go too well with cast discs either.
The Bendix have proved to be a little hard to get stocks of but are coming through now. Give Mike or myself a ring if you need any
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 15:38.
