Old 04-Apr-2012, 07:47   #1
welsh999 welsh999 is offline
Headlights stoped working (2003 999)
Hi just been out on a ride and noticed low beam not working,decided to ride with high beam and thats not working.The side light and dash light up and if i use the pass switch the high beam does work.I suspect the headlight relay but electrics are a mystery to me.Any ideas?
Nige
Old 04-Apr-2012, 09:15   #2
Without sounding too patronising, maybe you should just check the headlight bulb(s) first - the may just have coincidentally failed at the same time.
Second culprit would be a fuse - if one bulb went it may have taken the fuse with it which stopped the other from getting power.
Finally check the relay as that too may either be duff or on it's way out.
Old 04-Apr-2012, 12:39   #3
Yep,probably the h/light relay.
Its clipped inside the headlight casting.You can get to it by removing the plate under the nose of the fairing.Quite common for the pins to corrode.
Old 04-Apr-2012, 15:07   #4
+1 to this.
Old 04-Apr-2012, 17:55   #5
Thumbs up
Bulbs both OK and fuse checked ok too
Old 04-Apr-2012, 17:56   #6
Will get a relay i think, Cardiff have some in stock at £6:50 worth a go.
Old 06-Apr-2012, 16:43   #7
New relay and its all sorted. Thanks all
Nige
