Old 07-Aug-2004, 15:21   #1
Mood: Come on spring!!!
Mounting the clocks
Just fitted the new headlight housing to the 748r, since the old one was destroyed i couldnt tell how the clocks were mounted to the housing, Now i can see it rests on 2 rubber blocks, and it is bolted at the right hand side. (Only one bolt to hold the clocks on? is this right?) If thats how its mounted there must be a spacer because there is a gap between the housing and the clocks when it sits on the rubber blocks! So what is the spacer and what sort of bolt is it?
Old 07-Aug-2004, 18:56   #2
neil748r neil748r is offline
From memory, there should be 3 rubber stand-offs, not 2. Couple of quid each from your dealer.
Old 07-Aug-2004, 19:16   #3
yep 3 rubber standoffs isolate the clocks from the vibes. they are about 12-15mm long with smm threads at each end
Old 10-Aug-2004, 18:14   #4
HANCYM HANCYM is offline
Clocks
You can also get these same rubber mounts from RS Components in corby
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 18:18.
