Old 08-Aug-2004, 18:43   #1
swansea jack swansea jack is offline
Mood: red hot !
suspension & others
Hi all, bought my 996 back in march; wish I'd done it sooner!!
I have spent a small fortune tarting the bike up to make it look good, so now I an concentrating on the handling / performance. I am thinking about buying an Ohlins rear shock. What difference will I see ? The Showa shock seems a little stiff, & when I hit a series or bumps, I end up sitting on the tank ! Can anybody give me some advice on front & rear suspension settings. I am 14 st 10 lbs fully kitted up. I am also thinking of going a tooth smaller on the front sprocket. What do u all think ?
Thanx guys,
[Edited on 8-8-2004 by swansea jack]
Old 08-Aug-2004, 18:55   #2
If you mainlyu ride one up then swapping to a Ohlins shock from a single seat version (SPS or R) will give you a spring that is 1kg/mm softer and should improve the rear end feel.
if this the way you intend to go I wouldn't do to much to the front until you have the back end sorted.
One tooth smaller is a popular mod and works well on Ducatis, jsut need to make sure the ride height is adjusted to the right setting afterwards.
Can't advise on actual settings as I'm a bit lighter than you.
And welcome to the board
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 18:17.
