Old 11-Aug-2004, 15:28   #1
moozaad moozaad is offline
Bikes: Ducati ST2
Mood: Fruity
clutch plates
Hi
Its time to replace my worn out stock clutch plates.
I've heard alot about barnett but I can't find a supplier. Are there any other recommended makes?
I also have the stock basket which I probabily wouldn't mind changing if I had too. It has some slight indents (or are they factory added) from the plates but is otherwise undamaged.
suggestions?
Old 11-Aug-2004, 16:51   #2
PDQ are the UK importers of the Barnett Clutches. Not the cheapest option though if I remember correctly and they only do the plates, no basket.
The other more common options are
stock Ducati parts, steel
Stock ST4S parts, which are alloy basket and plates
The stock Ducati basket, either alloy or steel with an alloy performance pack in from either Bucci or Surflex.
STM 48T basket and plate kit, all alloy.
Your dealer should be able to help with the sock parts, JHP with the Bucci and surflex packs or mail me for info on the STM.
Old 11-Aug-2004, 16:55   #3
Decisions, Decisions ...
Ducati Clutches
The Ducati dry clutch on most models use steel plates, hub and basket. It’s noisy and it’s heavy, compared to aftermarket units, but it’s pretty durable and the friction material lasts at least as long as aftermarket plates. The reason that they’re noisy is that each time you shift, the edges of the plates hammer the fingers of the basket, causing each to deform, causing the gap between them to get larger, causing higher impact forces, and causing more rattling noise when the clutch is disengaged. So they get louder and louder until the plates and basket are replaced.
You’ll need to replace the plates when the thickness of the friction material gets too thin to prevent slipping. You’ll notice a little slippage first when starting-off in first gear, but when it starts to slip in top gear it’s time for a new clutch pack. Depending on the mileage and the depth of notching, you will probably will want to replace the basket at the same time. A notched basket will be louder, but I’m not convinced that it makes it any more difficult to for the plates to separate when disengaging the clutch. But replacing just the plate stack, which then has to engage the basket notch pattern worn-in by the previous plates, will possibly affect your ability to shift smoothly.
The price of the Ducati original equipment manufacturer (OEM) parts varies from dealer to dealer, so shop around. Also, the 999 comes with an aluminum basket that works on the older bikes. It retails for less money than an alloy aftermarket part.
Aftermarket Clutches
After market clutch components are marketed as performance items with unique features that are intended to address design defficiencies in the OEM clutches. Foremost is lighter weight.
Aluminum drive and friction plates, basket, hub and pressure plates combine to reduce rotating mass as well as overall bike weight. Less rotating mass in the engine allows it to change rpm more quickly and less overall bike weight improves acceleration, braking and handling.
However, the reduced mass offered by an aftermarket clutch alone is not very significant because the clutch turns once for every four revolutions of the flywheel. Consequently, it is accelerated one quarter as quickly as the flywheel, so rotational weight reduction at the flywheel, gram-for-gram, will give you four times the effect as weight reduction at the clutch. Reducing the flywheel and clutch weight often will adversely affect drivetrain smoothness (so unlike lighter wheels, for example) this is not necessarily an overall improvement for the street.
The weight savings from an aluminum clutch basket and plates is about 3.5 pounds, less than 1% of the overall bike-plus-rider, so any improvement in performance is not really of major importance in deciding to change to an aftermarket unit.
Clutch durability is another area where aftermarket clutches are marketed as an improvement over stock clutches. Clutch life varies widely from rider to rider but all direct comparisons suggest that the Ducati OEM clutch plate friction material has outlasted the clutch plates from aftermarket manufacturers. In one case 25K vs. 16K miles.
So, at roughly the same price, the OEM plates seem to be the better buy.
There has been some innovation to try to address the durability issue associated with the plates impacting and notching the basket.
For example, STM has tried to overcome this problem by increasing the number of tabs on each plate (and the number of basket fingers) from the stock 12 to 48 tabs. The intended result is to distribute the impact loads over a larger tab-basket contact area (lower psi) to reduce notching to the clutch basket fingers and mushrooming of the plate tabs. Only STM makes a 48-tab clutch pack, however.
Nichols Manufacturing designed their CNC-machined aluminum basket with wider basket fingers that results in larger finger contact area and consequently lower impact stresses, particularly when combined with their Barnett clutch pack where extra care has been taken to initially minimize gaps.
Another option is a Barnett aluminum basket with stainless steel inserts to protect the basket fingers.
Keep in mind that when you mix steel and aluminum, the softer metal deforms preferentially and clearance gaps suffer, more than for steel-to-steel. So if you have a steel basket, stick with steel plates.
[Edited on 8-11-2004 by Shazaam!]
Old 11-Aug-2004, 17:42   #4
Bikes: Ducati ST2
Mood: Fruity
cool thanx for the info
I've always been tempted by nichols mnf's dual spark cyclinder head
I'll give ducati coventry a ring, see if they have the clutch parts I need. Is there any UK based online suppliers for ducati stock bits so I can compare prices?
Old 11-Aug-2004, 17:46   #5
I'm running alloy ST4S plates in the standard steel basket. They are just about on their last legs now but have no appreciable wear on the tangs, hence no wear on the basket. Lovely and quiet as well and they lasted about as long as the standard all steel set up. I'm going to replace them with the same thing.
Old 11-Aug-2004, 18:30   #6
Ducati have their dealers on the same price list so JHP won't be any cheaper than anywhere else. You may get a "deal" if you show 'em your DSC memebrship card.........if you have one? If not, it could be worth joining
Old 11-Aug-2004, 20:51   #7
Bikes: Ducati ST2
Mood: Fruity
Mines actually in the post coz you lot are such a nice bunch ...and I fancy the trackday discounts
rockhopper, whos alloy plates are you running and how long have they lasted?
Old 11-Aug-2004, 21:05   #8
They are the genuine Ducati ST4S alloy plates from JHP. Cost about £100 i think. I forgot to note the mileage when i fitted them but the date was November 2002 which was about a month after i got the bike. It had 11,000 miles on it then and its just coming up to 20,000 now. The clutch has just started to slip if i'm not careful pulling away. I'll get another trackday out of them i think!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 19:05.
