Old 13-Aug-2004, 00:03   #1
Fuel pump
When I first had the T8 the fuel pump sounded quite loud and primed fairly quickly it now sounds as if it is straining to prime,is it on the way out and how much are they?
any help on this greatly appreciated as i dont want to be stranded somewhere.
thanks
ian
Old 13-Aug-2004, 00:51   #2
where is the fuel filter on the 888 if this hasn't been replaced then it may be clogging up and restricting fuel flow
Old 13-Aug-2004, 01:34   #3
Check out the price list on www.spareshack.com, sadly I think you need to know part numbers
Gud Luk - Frank
Old 13-Aug-2004, 09:52   #4
Yep,could be the fuel filter,as Skids said.The filters are around 6 or 7 quid to replace.If your Duke dealer has'nt got one,go to a BMW dealer.(Take the old one as a pattern.)
Forgot to mention,the filter is inside the fuel tank.Get to it by removing the filler cap and boss,then unclipping it from the tank along with the pump and pipework.(Its better if the tank is drained first! )Its an aluminium cylindrical thingy!
[Edited on 13-8-2004 by KeefyB]
Old 13-Aug-2004, 13:49   #5
Nattyboy Nattyboy is offline
Nattyboy's Avatar
Mood: Back down to 3 :>(
Im with the other lads..'proper' dealers are sposed to replace this and inevtiably (some) dont most of the time The T8 is reknowned for having a struggling fuel pump due to clogged filters.
Worst case.if you do need a fuel pump then I do have a brand new one here with some special discount for a man of taste like yourself !!! The part number is 43040041A, and its marked up '996/M900'..not sure if they are generic but the offers there if it will fit ..? Nelly/Kev..any ideas
Nat
Old 14-Aug-2004, 23:20   #6
pump
thanks everyone
Ill try the filter route first.
keep you informed
Old 15-Aug-2004, 07:15   #7
If you find you need a pump,and if Nats pump wont fit,try your local Weber car specialist.My mate got a pump for his 907ie for half the price that Ducati wanted.Take your old one along as a sample.
Old 15-Aug-2004, 10:10   #8
weeveetwin's Avatar
Ian - If the fuel filter is blocked it puts extra strain on the battery/charging system since the pump is running more often and thus drawing more electrical load. My own bike had a clogged filter some time before I bought it (according to the history/service log), and when a new one was fitted, the 'flat battery' syndrome it was prone to was miraculously cured! Strange but true.
