Old 20-Aug-2004, 13:52   #1
Murray Mint's Avatar
Suspension and clutch question
Can anyone give me some advice on how to adjust the spring preload on the rear suspension unit, will I have to remove the exhaust connecting pipes to get the ‘C’ spanner in there or is there another way of doing this job.
Also, has anyone got a clutch basket holding tool that I can borrow, I’m located in Crawley, West Sussex.
Murray Mint
Old 20-Aug-2004, 17:10   #2
chris999 chris999 is offline
Mood: red and proud !!!!
you should be able to adjust without removing bits,, bit tricky...
Old 20-Aug-2004, 19:34   #3
Ive got two types of 'C' spanner and none of them work.I ended up using a hammer and a punch.You wont damage the lockrings if you're carefull and make sure the punch is square on.
