Old 23-Aug-2004, 18:02   #1
desmojen desmojen is offline
Mood: DOH!
748R slipper clutch
Hi fellas, I got a 2000 748R which is now on its second clutch. Is clutch wear a normal problem with these?
This clutch has done around 4000 miles of road, track and race use and the plates leading edges now have those big hooks on, plus the basket is worn too.
Any advice?
Would an STM one be better?
Thanks in advance
Old 23-Aug-2004, 18:15   #2
Lily Lily is offline
Mood: stiff and tired
Jen
I have the standard 'slipper' that came with mine, I had the plates and basket changed and now have the carbon plates which are great, but seem to have worn in about 5k with little track riding.
[Edited on 23-8-2004 by Lily]
Old 23-Aug-2004, 18:37   #3
Felix Felix is offline
TBH, with race and track use, you've done well to get 4000 miles! Slipper clutches wear at a greater rate than regular clutches, even if you don't race them.
Old 23-Aug-2004, 19:23   #4
Mood: DOH!
Thing is, theres still miles of meat left in the actual plates friction material, it's the wear in the basket and on the plates teeth that annoys me, it means you have to fit the whole thing every time and not just a set of plates like any other bike!
Thats why I wondered if the stm item is any better?
Old 23-Aug-2004, 20:47   #5
If you mean the 48 tooth jobbie, I don't know if they last any longer. Maybe it will and Alan at AJR would know. Give him a ring. He's a good bloke.
The downside with the 48 tooth clutch is that you have to use STM plates and basket as no others will fit.
Your experience with wear is very typical, I am afraid. You learn to accept it with time...
Old 23-Aug-2004, 21:13   #6
Mood: DOH!
I always find it hard to accept expensive things.....................unless they are presents of course!
Old 24-Aug-2004, 13:22   #7
Harv748 Harv748 is offline
Harv748's Avatar
The STM 48 tooth jobbie will be better for wear as the load from the plates will be spread over the surface of 48 teeth rather than the standard number.
Obviously a bit more expensive to buy to start with, but if wear is your main concern then it may well be worth it in the long run???
Old 24-Aug-2004, 13:29   #8
The 48T STM plates will last longer. Sendo Ducati are seeing 3 or 4 meetings in BSB with them compared with 1 meeting on stock parts.
They are on "promo" at the moment. £250 for the plates and basket. Works out about £50 more than buying the stock parts. Looks better to as the basket is anodised red
drop me a mail if you'd like more info, or call Alan at AJ Racing.
Old 24-Aug-2004, 13:33   #9
Nelly, do you know if they make one that fits the Corse bikes? I suppose they must if Sendo are using them. Is it really the same parts as the off-the-shelf STM parts?
Old 24-Aug-2004, 14:40   #10
Mood: DOH!
Definately interested in an stm, might be a bit quieter as well?
How longs this offer on for?
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 22:42.
