Old 25-Aug-2004, 07:52   #1
martins martins is offline
Bikes: 2013 Monster 796 2012 Harley Davidson Softail Slim
Quick Change Carrier 996
How easy is it to fit one of these? has any one seen any instructions on the web? what tools are required, info appreciated
Old 25-Aug-2004, 10:10   #2
neil748r neil748r is offline
Dead easy. If you have access to a Haynes manual or Duc workshop manual just follow the procedure for changing the OEM rear sprocket.
The only tools you need which you may not have are a 41mm socket for the axle nut and a decent (fairly large) pair of circlip pliers.
You might also want to think about changing your cush drive rubbers while you've got it all in bits.
If it would be of use, I can e-mail you the relevant pages from the workshop manual - just let me know.
Hope that helps,
Neil
Old 25-Aug-2004, 13:19   #3
NBs996 NBs996 is offline
NBs996's Avatar
Mood: I love my 996 xxx
....and don't forget to put thread lock on them little bolts wot hold the sprocket ring to the carrier.
Not that I'm speaking from experience of corse!
Old 25-Aug-2004, 23:51   #4
Mr_S Mr_S is offline
Even with threadlock on I'm finding mine loose every 500 miles or so. Very paranoid about checking them at the moment.
I'm now on Loctite 222 to hold the bu&&ers in.
Old 26-Aug-2004, 10:39   #5
Try using nyloc nuts and Loctite.
Old 26-Aug-2004, 12:23   #6
moto748 moto748 is offline
Aren't they tapped holes? I'm sure they are on mine.
Old 27-Aug-2004, 11:13   #7
Yep, tapped holes, so NyLoc's aren't an option.
If Loctite 222 doesn't work, I'm getting a set of bolts drilled for wirelocking and going down that route instead, although it kinda defeats the quick change...
Old 27-Aug-2004, 11:59   #8
What make of carrier are you using? Renthal are studs and nylocs to hold sprocket to carrier.
Old 27-Aug-2004, 13:46   #9
Mine's from AJ Racing.
Old 27-Aug-2004, 14:07   #10
Mine's Talon.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 21:38.
