Old 18-Apr-2012, 18:52   #1
welsh999 welsh999 is offline
999 new clutch
After some help.
Put new clutch plates in as last set worn, clutch works ok but clutch is dragging when pulled in.If i put the rear brake on whilst on padock stands wheel stops as expected and the cluch stops spinning, engine ticks over fine.Was also tricky to get into neutral with engine running but bleeding the master cylinder sorted this. Will the clutch bed in or have i missed something.
Old 20-Apr-2012, 16:20   #2
Are you running a aftermarket slave cylinder? The new pack will be slightly thicker than the old one and a different slave will have a shorter throw.
As well as bleeding the master, do a full bleed as the slave may have took air in when the pressure plate was removed.
If you've got the reach, try setting the lever a little further out.
Old 20-Apr-2012, 19:48   #3
thanks Mate will give that a go.
Old 21-Apr-2012, 18:22   #4
Ok bled the slave cylinder and then the master again, gave a good flush through and now all working fine.
