Old 27-Aug-2004, 14:32   #1
DSC Member AK AK is offline
AK's Avatar
Haynes book of lies
Have you ever read or used a Haynes Manual? If so, here's a handy
Translation sheet.....
Haynes: Rotate anticlockwise.
Translation: Clamp with molegrips then beat repeatedly with hammer anticlockwise.
Haynes: This is a snug fit.
Translation: You will skin your knuckles!
Haynes: This is a tight fit.
Translation: Not a hope in hell matey!
Haynes: As described in Chapter 7...
Translation: That'll teach you not to read through before you start,
now you are looking at scary photos of the inside of a gearbox.
Haynes: Pry...
Translation: Hammer a screwdriver into...
Haynes: Undo...
Translation: Go buy a tin of WD40 (catering size).
Haynes: Retain small spring...
Translation: "Jeez what was that, it nearly had my eye out"!
Haynes: Press and rotate to remove bulb...
Translation: OK - that's the glass bit off, now fetch some good pliers
to dig out the bayonet part.
Haynes: Lightly...
Translation: Start off lightly and build up till the veins on your forehead are throbbing them re-check the manual because this can not be 'lightly'what you are doing now.
Haynes: Weekly checks...
Translation: If it isn't broken don't fix it!
Haynes: Routine maintenance...
Translation: If it isn't broken... it's about to be!
Haynes: One spanner rating.
Translation: Your Mum could do this... so how did you manage to botch it up?
Haynes: Two spanner rating.
Translation: Now you may think that you can do this because two is a low, tiny, 'ikkle number... but you also thought the wiring diagram was a map of the Tokyo underground (in fact that would have been more use to you).
Haynes: Three spanner rating.
Translation: But Nova's are easy to maintain right... right? So you think three Nova spanners has got to be like a 'regular car' two spanner job.
Haynes: Four spanner rating.
Translation: You are seriously considering this aren't you, you pleb!
Haynes: Five spanner rating.
Translation: OK - but don't expect us to ride in it afterwards!!!
Haynes: If not, you can fabricate your own special tool like this...
Translation: hahahahahahahahahahahahahahahahahahahahahaha!!!!
Haynes: Compress...
Translation: Squeeze with all your might, jump up and down on, swear at, throw at the garage wall, then search in the dark corner of the garage for whilst muttering "bugger" repeatedly under your breath.
Haynes: Inspect...
Translation: Squint at really hard and pretend you know what you are looking at, then declare in a loud knowing voice to your wife "Yep, as I thought, it's going to need a new one"!
Haynes: Carefully...
Translation: You are about to cut yourself!
Haynes: Retaining nut...
Translation: Yes, that's it, that big spherical blob of rust.
Haynes: Get an assistant...
Translation: Prepare to humiliate yourself in front of someone you know.
Haynes: Turning the engine will be easier with the spark pugs removed.
Translation: However, starting the engine afterwards will be much harder.
Once that sinking pit of your stomach feeling has subsided, you can start to feel deeply ashamed as you gingerly refit the spark plugs.
Haynes: Refitting is the reverse sequence to removal.
Translation: But you swear in different places.
Haynes: Prise away plastic locating pegs...
Translation: Snap off...
Haynes: Using a suitable drift...
Translation: The biggest nail in your tool box isn't a suitable drift!
Haynes: Everyday toolkit
Translation: Ensure you have an AA Card & Mobile Phone
Haynes: Apply moderate heat...
Translation: Placing your mouth near it and huffing isn't moderate heat.
Haynes: Index
Translation: List of all the things in the book bar the thing you want to do!
For Added Haynes Fun:
Go to the first section, Safety First, and read the bit about Hydrofluoric Acid - do you really want the advice of a book that uses this form of understatement???!!?
Now look at the lovely colour section on body repairs - as you look at these two pages say to yourself over and over until it sinks in "mine will never look like that..."
Old 27-Aug-2004, 14:37   #2
baylissboy baylissboy is offline
baylissboy's Avatar
Mood: Happy as Larry!!!
Ain't that the truth!!
Old 27-Aug-2004, 14:42   #3
love it...so true, especially the part on making your own tool !!!!
Old 27-Aug-2004, 14:46   #4
BDG BDG is offline
BDG's Avatar
Excellent, but there is one section missing re flushing oil.
One numpty at work was told that if he flushed the engine out it would be better.
He didn't use flushing oil, he just drained the oil, left drain plug out and put a hosepipe in the oil filler and turned the tap on for 10 minutes...... i kid you not.
when finished he filled it up with oil again!
I've never seen a diesel astra van produce so much white smoke before it died.......
Old 27-Aug-2004, 16:09   #5
uncle porry uncle porry is offline
uncle porry's Avatar
speaking of diesels BDG, i use a kangoo van for work and every time i go to fill my bike up i always reach for the derv pump by mistake/out of habit...one of these days its gonna cost me a shed load of cash to fix my bike having filled it with diesel...god i hope not...
Old 27-Aug-2004, 16:15   #6
Haynes....."assembly is a reversal of the above......"
Translation......... we couldn't figure that bit out!!
Old 27-Aug-2004, 21:46   #7
Mood: Avatar what Avatar
Great love it
Old 31-Aug-2004, 03:38   #8
tont2002 tont2002 is offline
Mood: waiting til next summer ;)
In case you havent got the haynes to check the last bit!!!
This extremely corrosive acid is formed when certain types of synthetic rubber, found in some O-rings, oil seals, fuel hoses e.t.c, are exposed to temperatures above 400C. The rubber changes into a charred or sticky substance containing the acid. Once formed, the acid remains dangerous for years. IF IT GETS ONTO THE SKIN, IT MAY BE NECESSARY TO AMPUTATE THE LIMB CONCERNED.
Old 31-Aug-2004, 12:57   #9
kwikbitch's Avatar
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 07:46.
