Old 28-Aug-2004, 20:22   #1
martins martins is offline
Bikes: 2013 Monster 796 2012 Harley Davidson Softail Slim
Rear Hub removal
Prior to fitting a quick change carrier-(Neil Stedman has offered to post me details of how to fit the carrier-appreciated) I went into the garage to remove the rear hub for polishing, but the retaining bolts keep going around, how do you stop them from rotating in order to remove the nuts to get the Hub off?
Help appreciated
Old 28-Aug-2004, 20:28   #2
desmojen desmojen is offline
Mood: DOH!
You take the big nut off at the front and then take off the sprocket/carrier as a oner. Then you will see a large allen key in the back of each cush drive to hold while you undo the nut.
Old 28-Aug-2004, 20:35   #3
Rear hub removal
Sorry to be thick, do I need to remove the chain?
Old 28-Aug-2004, 21:15   #4
Mood: DOH!
Lol, don't worry, I'm no einstein either!
The chain will come off when you take out the sprocket, you don't have to take it right off the bike though.
Old 28-Aug-2004, 21:55   #5
Mr_S Mr_S is offline
Have a look at the file here, it's the one I used and it's well written.
I'd recommend reading it through first though, as the allen key needed to remove the cush rubbers isn't mentioned in the tool list (12mm IIRC)
http://www.ducati.ms/ubbthreads/down...ch_id=177?Cat=
Jason
Old 28-Aug-2004, 23:02   #6
Rear Hub Removal
Thanks guys, I appreciate all of your help.
I have never been one to do my own bike work, but as I am now over 40 I thought it is about time I had a go, a bit scarry but I am determined to fit my own quick change carrier.
all I need to ask you now the the size of the large Hub nut?, so I can pop around to borry from my mates Snap on Tool box!, I have the 46mm for the wheel I even have a torque wench!-all of my own!
Old 29-Aug-2004, 00:36   #7
41mm then is what you'll be needing. If you can borrow one with the shoulders machined down you're less likely to slip off the nut as it's quite shallow.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 11:18.
