Old 29-Aug-2004, 21:55   #1
pasta burner pasta burner is offline
Hope someone can help??
Hey all, I have a 1999 750SS. I rode to work in the morning rode home no problems. about 2 hours later I went to meet some friends for a ride and when I tried to start the bike All I heard was popping from fuses blowing. Checked all the fuses and I blew ones labeled "right switch"(7.5 amp) "injection"(5 amp) and a 40 amp Maxi fuse for "Electronic Regulator"
I replaced them all and Keep blowing the one labeled "right switch" when I push the starter button. Can anyone help? I know next to nothing about this except that up untill now all I did was put the key in and go
Old 29-Aug-2004, 22:42   #2
Felix Felix is offline
Sounds like your starter motor relay might have shorted. If your mechanically minded, you might disconnecting the little plug behind the relay. Also, check the wiring loom from the starter switch on the right handle bar to see if it chafed through to metal anywhere.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 15:42.
