Model Specific - Discussion, Technical Problems and Help
998 / 996 / 916 / 748
> Ohlins steering damper
30-Aug-2004, 13:52
Chrisiball
: Come on spring!!!
Could some one tell me what the part number is for the Ohlins steering damper i.e SD ??? and what the stroke is?
Chrisiball
Send a personal message to Chrisiball
Find More Posts by Chrisiball
30-Aug-2004, 18:51
skidlids
: Its ONLY a Bike Club
Go back a couple of days to Desmojens post about her new Ohlins shock and you will find a direct link to the PDF file for the Steering damper
skidlids
Find More Posts by skidlids
30-Aug-2004, 20:32
neil748r
Assuming it's for a 748/916/996/998 then the damper is 68mm stroke.
Part number SD121 (just the damper)
Part number SD120 (damper including fitting kit)
neil748r
Send a personal message to neil748r
Find More Posts by neil748r
30-Aug-2004, 22:56
4
skidlids
http://ducatisportingclub.com/xmb/vi....php?tid=11546
http://www.ohlins.com/pdf/mounting_i...ions/sd120.pdf
there you go made it easy for you
skidlids
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 21:34.
