Old 31-Aug-2004, 15:31   #1
peterg peterg is offline
What is the Torque Setting? Clutch
I am awaiting the arrival of a load of carbon and alloy parts from Casoli.
One of which is the red anodised clutch pressure plate.
I would like to know what the clutch springs should be Torqued down to??
Peter G
Old 31-Aug-2004, 15:45   #2
8 or 9 Nm. No tighter, and make sure you apply a good smear of Copaslip to the threads. They are buggas for seizing and then the heads rounding out.
Old 31-Aug-2004, 15:46   #3
Someone will be along soon with the right answer but the Rockhopper answer is not very tight. An ordinary allen key will do if you dont have a torque wrench. The weight of my 12 inch bar was enough to snap one of the bolts on my ST2.
Old 31-Aug-2004, 15:46   #4
5 INCH-pounds to avoid stripping the threads. The spring tension will prevent them from loosening.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 07:45.
