Old 01-Sep-2004, 12:15   #1
peterg peterg is offline
Can you use the standard exhaust with Termi Ecu
I was looking at doing atrack day at the Mira testing ground on the 25th sept.
But i have noticed in the rules that the noise limit is set at 80db.
I have Termis fitted to my bike, and wondered if I could just simply swap the Termi exhaust with the standard without changing the Ecu.
Or is ther a easy way of making the Termi quiet, for the duration of the trackday.
Regards
Peter g
Old 02-Sep-2004, 10:40   #2
DAVE HARRIS DAVE HARRIS is offline
I run my old 916 with the standard silencers and a jhp termi chip, If anything it pulls better than with the termis on up to about 8500rpm. The engine may run rich in certain areas of the fuelling map but rich running should not damage the engine over short periods, lean running on the other hand can melt pistons and damage valves.
In my experience you should be ok
dave
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 07:45.
