Old 25-Apr-2012, 00:01   #1
jangol jangol is offline
Bikes: 1098s, 749
pass light button not working
Got an early 749bp, my pass light doesn't do anything? Any ideas
Where should I be checking?
Old 25-Apr-2012, 11:27   #2
Does the regular hi beam switch work? If not, probably the relay or fuse. If it does, then start with the switch gear. Check the internals and give them a clean and a spray of wd40.
After that, it's checking of the wiring.
Old 25-Apr-2012, 23:49   #3
Bikes: 1098s, 749
Cheers for the post. lo & Hi beam work.. will check the switch?
Just thought it may be a blank button, which may not do anything..
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 19:31.
