Old 27-Oct-2004, 18:34   #1
keefer keefer is offline
keefer's Avatar
no didn't need any special tool but I wouldn't recommend you get started unless you have a fair selection, hours wise hard to say really I spent a couple of evenings getting the bike ready to remove the engine.
So fairing, tank, exhausts, injectors, rads oil and water, rear subfraime, headlight and clocks then unplug the wiring marking up anything you think you may forget as you go along. I also took lots of digital picks of where the wiring is cable tied to the frame so as to get it correct on replacement.
I then got a friend to come round to help me remove the engine. [put some wd40 on the bolts the night before]
then its forks head stock and then swingarm out and that plus or minus a few bit and bobs is about it. That took me a couple of nights and a Saturday afternoon.
yes you could get the headlight bucket done im just about to get the yokes done as I had them anodized but it looked crap.
and finally if the place you take it to knows what they are doing then they should cover up the holes that take bolts in them with bits of rubber.
And no heat wont effect it, it's baked off in a oven and very tough.
[Edited on 27-10-2004 by keefer]
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 14:01.
