Old 09-Apr-2013, 00:20   #1
Mello-Yellow Mello-Yellow is offline
Bikes: 848 EVO & Multi 1000ds
Mello-Yellow's Avatar
Mood: When's the sun coming out
848 evo rebound adjustment
Having a twiddle with the suspension on my 2011 evo. First chance since had to ride it in anger due to the poor weather of late. Anyway according to my manual the stock setting for rebound is 12 clicks from closed, I could only count 8 and it was set on 3. As far as I know the forks have not been modified by previous owner. Is this right or is the manual wrong. Can some check theirs to compare mine with.
Old 09-Apr-2013, 03:19   #2
Turn the screws at the top of the forks clockwise till you hit the stop—then 12 clicks anti-clockwise to decrease damping and return to the factory setting.
BTW about half of the magazine tests of superbikes set fork rebound damping at 4 clicks out.
For the shock, kneeling at left side of bike, turn the knob anti-clockwise to decrease damping till you hit the stop. Then turn the knob clockwise and count the clicks.
Old 09-Apr-2013, 09:41   #3
I turned them all the way in and could only count a max of 8 clicks. I settled on 5 clicks so sounds like I'm pretty near then.
Old 09-Apr-2013, 23:09   #4
8 clicks doesn't sound right. May be worth having it looked at
Old 09-Apr-2013, 23:45   #5
Yup that's what I thought. I have double checked made sure I have not miss counted. The adjuster just does not want to turn past 8 clicks. Not going to force it either and make things worse. K tech kit to sort it lol.
Old 10-Apr-2013, 19:09   #6
Good a reason as any for an upgrade
Old 10-Apr-2013, 19:30   #7
If you only have 8 clicks when you should have 12, sounds as if the forks have already been apart and reassembled with the fork caps screwed on to far
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 12:02.
