Old 08-Oct-2005, 16:42   #1
http://www.ducatisportingclub.com/xm...3429#pid114740
Obviously, stainless springs are more attractive with an open clutch cover. The problem is (often) that making the same size coil from stainless material gives a slightly different spring stiffness - so you may need to use a slightly different height clutch plate stack to get the same preload.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 23:12.
