Old 23-Oct-2005, 20:19   #1
ronnie_rjm ronnie_rjm is offline
749R Cutting Out
Hi - just registered so finding my way about, but above topic caught my eye. I have experienced similar problem (cutting out) but have noticed also that temperature indication has always been below my, til now, normal 71degrees. Local dealer indicated that 69 and below tends to give rise to cut-outs. I haven't bothered altering tickover and bike will be laid up shortly anyway.
I haven't experienced flat spots (except when I installed Power Commander and loaded the supplied map which was supposed to match my set-up of 54mm Termis, stock air filters). Flat spot in my case corresponded to 6-7 thousand revs range and negative map settings for vertical cyclinder. Have since loaded zero map and cured problem and await info from Dynojet on the map.
Lastly - I see that its possible to race Desmo Due but are there any other opportunities for other Ducati owners such as me to compete with other Ducati owners under the Sporting Club ?
Any infoor guidance appreciated
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 11:28.
