General Motorcycles only
Old 31-May-2006, 10:28   #1
phil_h phil_h is offline
phil_h's Avatar
The key paragraph is
"So, unlike the 800, where I was looking for some extra fuel to find best power, the 1000DS seems quite happy as is. Maybe the dual spark plugs help here too – I’ve seen 4V go as high as 17:1 air/fuel at WOT and still make almost the same power as the correct fueling, so good combustion does help compensate for a lean mixture. With a plug on either side of the chamber, I’d expect combustion to be much more consistent and stable on this engine. Whether this also corresponds to improvements in fuel economy over the 900 we’ll have to wait and see, but I wouldn’t be surprised if it was better. The extra compression will help there too."
You are basically looking for around 14 through the range, but as the man says, modern/good design helps bigtime !
As far as reading plugs goes ... its not as easy as it used to be as unleaded produces a lot of black **** (sorry - technical term !) even when its burning well. You have to look right on the end of the centre electrode to get the real colour - and of course you want a brown tinge for good combustion, magnolia meaning too lean, white meaning expensive bills are on the way, and really brown meaning you just have to fill up more often
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 13:15.
